Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help on picking transmision
Old 11-27-2012, 12:29 PM
twinpilot001 twinpilot001 is offline
Last wiki edit: Stroker 351 W Ford Motor=Building
Well- the actual end result will be about the same as the auto.the final drive ratios are all around .73-1- in old days before the od trannys it was always 1-1- yet today with any od. trans all about the same- must change rear end ratio to get any large benefit in speed
