Need help with Powerglide valve body screen - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2009, 08:42 PM
I am doing a stock rebuild on a Powerglide in a 1964 Impala. This is the original transmission to the car and has never been apart. I have attached a picture of the two screens I have. The longer one fits into the valve body, I removed it while cleaning. The shorter one measures just over 1/2 ". I found it in the bottom of my parts washer when I was finished cleaning parts. I can't find anywhere that it will fit in the upper or lower valve body. Anyone know where it goes? Any help is appreciated.
Thanks,
Todd
Old 12-09-2009, 02:51 PM
junior stocker's Avatar
I looked in both Chiltons and Motors Manuals, and the "long" screen is'nt even made note of, but I've come across that screen many times; I build Powerglides for the local bracket racers. The short screen IS NOT from your transmission, it must have come from something else cleaned previously. Also, in the instructions that come with TransGo's Powerglide shift kit it says, "if this screen is used in your transmission, reinstall it"; that tells me not all Powerglides had that screen, and that perhaps it is'nt completely necessary.
Old 12-09-2009, 03:15 PM
I have the factory 1964 manual and it does not show either screen. The smaller screen did come from this transmission, the parts washer was clean when I started. I'm thinking it could have been in the governor. I will take it back apart to check.
Old 12-09-2009, 07:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the long screen looks like an old skool t-400 governor screen... the short one looks like a C4 trans governor screen... wild guess on that.
The glides I have worked on over the years had no such screens in them..
Old 12-10-2009, 12:25 PM
I disassembled the governor and found where the small screen goes.
ID:	42432   Click image for larger version
Old 12-11-2009, 11:01 AM
Just curoius, if you just disassembled the govenor, how'd the screen get out? I went back and looked at the books again, no mention of a govenor screen. It's probably something that's routinely left out at rebuild time. At least you found out where it goes.
Old 12-11-2009, 01:42 PM
I had already had the governor apart, cleaned, reassembled, and reinstalled. It fell out while I was cleaning it. I just hate having left over parts!
Powerglide electric shift/Trans brake valve body. junior stocker Transmission - Rearend 8 03-29-2011 06:13 PM
I lose compression w/ valve adjust drivehard Engine 5 11-23-2009 10:29 AM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Bad Valve Body? HawkZ28 Transmission - Rearend 2 02-26-2008 08:55 PM
Full Manual Valve Body TH-400 Chezelle Transmission - Rearend 3 06-13-2003 07:47 PM
