Need help with pressed in wheel studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 05:49 PM
Last journal entry: Bringing home the 401 Nailhead
The wifes 39 Willys came with a 12 bolt Chevy rear. I have no history on it but believe the axles to be stock. One of the 7/16" wheel studs spun when trying to remove the lug nut. I finally got the nut off, removed the drum and the stud in question just pushed out. I miced the knurled end at .465 I also tried to mic the hole in the axle with my dial bore gauge but because of the knurl I could not get a accurate reading. A search for studs returned a range of .472, .475, .480 and .486 knurls. Anyone know how large I can go on the knurl and still press it in. Would you recommend I get a larger knurl and drill the axle to match? I so how much undersize should I drill the axle?
Old 06-13-2010, 09:15 PM
327NUT's Avatar
No expert on this but I would clean up the old nurl marks and maybe go with the .475 stud. Give it a trail fit to see if it will be feasable, if it looks like it will be too small to bite into the axle flange for a good tight fit then go to the next size bigger.
Old 06-14-2010, 09:00 AM
I just tack weld the stud to the axle flange when this happens.
Old 06-14-2010, 11:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The OEM knurl diameter is 0.472". The amount of clearance that is coming from the worn knurling and how much is from the worn hole in the axle will decide which size knurl you'll be able to use.
In stud applications, for a 7/16" stud, the tolerance for the hole size for the lug is 0.005" to 0.008" less than the knurl diameter.
Judging from prior experience and by the looseness of the stud in your axle, I would first try a 0.472" knurl- in case the stud itself took the brunt of the wear.
Depending on that outcome, you could then use a 0.475" knurl, if the stock 0.472" diameter knurl feels loose.
Old 06-14-2010, 12:05 PM
Thanks Cobalt.
Will give it a try
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Anyone build their own English Wheel? Riot Racing Garage - Tools 16 03-24-2007 03:50 PM
Camaro wheel studs lluciano77 Transmission - Rearend 8 10-27-2005 10:38 PM
stripped wheel studs 6speedwagon Suspension - Brakes - Steering 2 06-06-2004 10:08 PM
Wheel stud replacement method jpd37 Transmission - Rearend 3 06-18-2003 11:07 AM
