Need Help With A Problem Gen V Big Block Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 12:42 PM
2 More Problems
(bought This Engine "ready To Run")
Went To The Dyno. Problem #1
Engine Vibrates...bad
It Is A 509, It Has An Externally Balanced Tci Flex Plate
And A Bds Counter Weighted Crank Hub
My Question Is:when I Disassemble This Should I Have It Balanced Externally And Keep The Flex Plate And Ctw Drive Hub Or Should I Have It Internally Balanced And Go With A Balance Neutral Drive Hub And Flex Plate?
Problem #2
We Got 1/2 Way Through A Pull And Coolant Began Shooting Out Of My Valve Cover Breathers.
Question: This Is A Gen V Block And It Has Edelbrock 24 Degree Aluim. Cyl. Heads. Does This Tak A Special Gasket?
Thanks In Advance.
Geo.
Old 04-19-2010, 01:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unless this is destined to see high RPM, there's nothing wrong w/an external balance, using the existing damper and flexplate- as long as these parts are correct for the BBC 1-piece rear main seal crank.
Your rotator might not have been dynamically balanced (spin balanced), it could have been statically balanced (piston/pins weight matched, rod small and big ends and total weight equalized)- this is a necessary step in obtaining a good balance, but isn't a truly "balanced" reciprocating assembly until the bob weight is calculated and the assemble spun.
I keep hearing that there's a gasket that allows a Mark IV head to be used on a GEN V engine- but when asked, no one has a part number- so far.
I have tried to find the answer to this w/o ANY luck here, other forums/internet and Summit tech line for a half hour while the guy looked through catalogs and asked his compadres.
Good luck.
Old 04-19-2010, 05:51 PM
BOBCRMAN@aol.com's Avatar
Fel-Pro gasket 8180 PT-2 will work so will Cometic C-5333040.
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 04:36 PM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 07:10 PM
4 bbl on big and small block Chevy Quick 58 Engine 1 11-21-2007 05:40 PM
Why I have Always LOVED the Small Block Chevy A glimpse inside reality Rob Keller Hotrodders' Lounge 54 11-09-2007 08:30 PM
Swapping to big block chevy low77ride Engine 5 09-15-2004 10:30 PM
