Need help puting a 74 Nova together - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2010, 09:20 AM
I just bought a 74 Nova roller. It needs a drive shaft and radiator among many other things.
What length is a Nova drive shaft and is there any other GM vehicles that share the same drive shaft i could pull from the junk yard.
What are the dimensions of the stock radiator and what other vehicle share the same size. I'm piecing together a Hot Rod from junk yard parts.
Old 07-21-2010, 10:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Besides here, you might try:
www.stevesnovasite.com
www.novas.net
Good luck.
Old 07-21-2010, 10:55 AM
tnsmith10's Avatar
when will it rain???
depending on what rear diff is in the car, the driveshaft will be either 51 1/2 (8.5 rear) or 52 1/2" long (7.5 rear).
as far as a radiator is concerned, i bought 1 for each of my venturas and both turned out to be aluminum. only around 120 bucks. small price to pay for something new with a guarantee. i wouldnt take a chance on a used rad especially with no warranty, because if it leaks, your s.o.l.
Old 07-21-2010, 01:28 PM
junior stocker's Avatar
Same as the Olds Omega, Buick Apollo, Pontiac Ventura, and the 67-69 Camaros'. 70-80's Camaros' should also work.
Old 07-24-2010, 07:09 AM
Ratoflic's Avatar
Big cubic inches small Chevy!
For The radiator..you have to put 19 X 26 unles you put the battery to the trunk to fit a bigger one like the one on an 79 camaro (19 X 31)
Stephane
Need Opions On Head, Carbs And Cams on My 74 Nova 350 Novasthefirst91 Engine 45 06-05-2010 08:03 AM
74 to 72 Nova Front End Conversion question! Ratoflic Body - Exterior 4 04-14-2010 08:10 PM
Bumper issue for '74 Nova SS Gil's NovaSS Body - Exterior 11 07-02-2008 05:35 PM
pulling transmission out of 74 nova CombatWombat Transmission - Rearend 5 04-25-2004 01:04 PM
moving in 74 nova bumper CombatWombat Body - Exterior 0 04-06-2003 04:50 PM
