Need help with Quadra-jet - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2007, 08:49 AM
well i put a cherry bomb glass pack and took the catylic converter off and a different air cleaner set up on a quadrajet carb and now its running really lean it feels like it looses power when you floor it. it runs good when we have cooler weather out though almost a night and day difference. how can i adjust the carb so i can make it run a little richer. I've heard of people bending the end of a piece of copper tubing so i can screw the jets out but what do you guys think i should do. any other tips on how to tune quadrajets would be apreciated too.
Old 09-11-2007, 09:23 AM
nitro_baller4692's Avatar
floppers forever
http://1320.com/
go to links and the quadrajet specs
Old 09-11-2007, 09:58 AM
any tuning tips for this carb? im not much of a fan of working on carbs but i need to get better at it.
Old 09-11-2007, 10:29 AM
302 Z28's Avatar
A QJ is not the first carb you should work on IMO.
Vince
Old 09-11-2007, 10:51 AM
its not the first carb i've worked on. i've worked on several before i just dont like to do it very much.
Old 09-11-2007, 12:35 PM
Jmark's Avatar
If it seems to "run lean" when you floor it, you most likely to go to a smaller diameter secondary metering rod. Very easy to change. 5 minute job. Easiest way is to pull them and mic the tip and then go about 10 thousands smaller. There are still lots of online carb places that sell rods and primary jets.
Mark
Old 09-11-2007, 12:57 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Titanium,
I can't get the link correct, google quadrajet carbs
the sixth one from the top
Rochester Quadrajet Tech info- The carburetor doctor
Good luck,
rich
holley jet size markzepp820 Engine 3 03-31-2007 10:23 PM
Q jet VS Holley?? Trav Engine 37 03-06-2007 06:11 PM
Jet 4l80e Tranny Chip Concern ALASKAN Transmission - Rearend 3 04-11-2006 08:02 PM
Ram Jet, Ramport, or StealthRam EFI? Blownolds Engine 0 12-16-2003 08:47 PM
how much jet is a jet... recomendations?? corona jon Engine 12 10-17-2003 11:27 AM
