need help with quadrajunk carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2002, 05:46 PM
New Member
Post need help with quadrajunk carb
i need help on tuning my carb i think the carb is running to rich pluggs are fouling
Old 10-26-2002, 05:49 PM
Post
Q-jet carbs are really tunable but have a few corrections that need to be made. What engine carb are you running?
Old 10-26-2002, 06:09 PM
New Member
Post
not sure what kinda carb it is rodchester or what but a 4 brl quad sitting on a 350 bored .30 over runs fine just that the pluggs are black i dont know where the mixture screws are or know much about carb work
Old 10-26-2002, 06:38 PM
Post
the mixture screws are on the front at the bottom of a Q-jet,the older carters,now edelbrock.and on the sides of holleys just behind the fuelbowl close to the bottom towards the front.
Foot to the floor,hair back,knuckles white.
Old 10-26-2002, 06:55 PM
New Member
Post
ok i found the screws do the go in or out
they are in the front theres one on the drivers side and one on the passenger side witch is witch
Old 10-26-2002, 07:43 PM
Post
there is one for each primary,to lean out the mixture turn them in. what i do is turn them in until the motor changes idle, then give them half a turn after you find where the idle returns.
Old 10-26-2002, 07:47 PM
New Member
Post
i will try that and see what i get might have to change the pluggs to
Old 10-27-2002, 12:08 AM
72 chevy's Avatar
Thumbs up
Hey tim! Check out thischart Good luck!
[ October 27, 2002: Message edited by: 72 chevy ]</p>
Old 10-27-2002, 02:37 AM
New Member
Post
hey member thanks for the chart comes up with different options to check
Old 10-27-2002, 01:04 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Try this Holly site is has the info on all the manufactures carbs made and troubleshooting.
George
http://holley-carburetors.com/
Luv the smell of NITRO in the morning.
Old 10-27-2002, 06:48 PM
New Member
Post
got it the carb works fine now i ujusted the mixture and leanded it out thanks for the help fellas
