need help quick, reverse cooling flow heads on old block...... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2003, 09:22 PM
Gino Fultano's Avatar
New Member
ok i got new heads off my uncle and they are from a 94-96 350 the casting numbers are 10125320. i research the cast number and it says reverse cooling flow. i am putting these on a 91 350 block, and i dont think its reverse cooling flow. will this be a problem? they are really nice heads, id hate to not be able to use them. thanks in advance guys.
Old 09-10-2003, 09:27 PM
BOBCRMAN@aol.com's Avatar
If you look at reverse flow heads you will see that the intake bolt pattern is different, also there is no water crossover passage front or rear, you have to use a reverse flow intake, gaskets and a reverse frow water pump to use this set of heads.
