Need help reading the stamps on my 350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2013, 10:11 PM
adam83's Avatar
I took the best picture I could, and this is it. The two stamps are frustrating because they are right on top of each other. I can see the partial vin, it reads T9Z 524529. I believe the T stands for GMC, the 9 stands for 1979, and the Z stands for the assembly plant GMAD FREMONT, and the 524529 is the partial vin, which is great because that means my engine is #'s matching to my truck .
Now what I cant read, is the stamp under it, which I think is the engine code. So far, it looks like V, something, something, 0, 1, 9, B, X. Frustrating
Old 01-25-2013, 11:19 PM
DoubleVision's Avatar
It appears to be TBX to me which comes up as:
TBX 1970 350 van & bus 255 4 C-10,20,2500,3500,3200
TBX 1979 350 conv. cab, a/t L LS9 155 4 K-10 to 2500
Old 01-26-2013, 12:08 AM
Check out this website with you numbers. How to decode Chevy Engine Codes
Old 01-26-2013, 12:11 AM
adam83's Avatar
I just looked it up too, I didnt know it was called a suffix code, thanks for the info. And that code is correct, the truck is a 79 GMC K2500
Old 01-26-2013, 12:14 AM
adam83's Avatar
Ive seen this site and would have used it, but I couldnt make out the engine code on my pad, as its covered by the partial vin
Old 01-31-2013, 09:38 AM
It looks like V14
SBC 406 Help/Validation on low Vacuum Reading @ Idle BMFZZ502 General Rodding Tech 2 01-01-2013 05:06 AM
283 SBC timing tab reading... normal?? Sin7 Engine 6 01-12-2012 08:14 PM
Vacuum reading with new cam sbc 350 eric32 Engine 17 09-05-2010 05:37 PM
Tip of the day 9-22-07 Number and letter stamps use in restorations. MARTINSR Body - Exterior 10 10-05-2007 05:49 AM
I was just sittin here enjoying reading engine posts and wondered BBC, SBC? fumplet Hotrodding Basics 22 09-25-2006 02:40 PM
