Need help with reclearing carbon fiber - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2011, 04:51 PM
Hey guys i am currently reclearing a carbon fiber hood and trunk. The parts are severely yellowed. I wet sanded with 1000 grit and it didnt teke the yellow out and 600 is not doing much of anything either. Am i doing something wrong. if i spray clear over it as it is will it show the yellow underneath
Thanks,
Taylor
Old 08-29-2011, 07:09 PM
Old Fool's Avatar
Thanks,
Taylor
Are you sure the carbon was not laid up with epoxy resin? If it was the yellow is the resin as it aged in the UV. Nothing will get rid of the yellowcolor if that is the case..
To combat that problem, GM uses some fancy $50,000 a gallon clear on the ZR-1 carbon fiber roof. ( or so the media reported at the introduction fo teh ZR-1)
Old 08-30-2011, 04:08 PM
milo's Avatar
point on positive
How does it look sanded and then wet with water?
If it shows yellow in water that is how it will look cleared
Pictures would be cool to see.
Here's one I did ...
http://www.a2zautoforums.com/showthread.php?t=2838
carbon fiber? kar-Enthusiast92 Body - Exterior 10 04-22-2011 07:57 AM
Carbon Fiber Help beagle General Rodding Tech 1 12-08-2004 03:29 AM
Carbon Fiber Help beagle Interior 1 12-07-2004 09:27 PM
Carbon Fiber Charles F. Smith Electrical 5 07-05-2004 09:48 AM
Carbon Fiber? daimon1054 Body - Exterior 2 06-30-2004 09:13 PM
