Need help refferencing a Manley Camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2010, 12:50 PM
A few weeks ago I took the heads and crank of my dad's 1967 Chevy-II 327 to the machine shop for restoration. The heads are finally being fitted with hardened seats along with new guides, studs and just about everything. I've come to find out that the distributor gear of my cam has been worn from improper shimming. To me this is almost the worst thing that could happen because this cam is the secret behind the most notorious engine known to this entire area. A secret that my father didn't have the chance to pass on to even me before his untimely death. To get to the point, there is no other cam set up that I want to use. If I can't use this cam then I want to find an exact duplicate. No compromise. So what I'm looking to do is find every spec of information I can on this cam so that I can reference it when finding a replacement. Here is all the info I have to use for Identification:
On the front end stamped: MANLEY 17415
On the rear end (distributor end) stamped: 17415 1247
Orange (maybe red) stripes painted in between distributor gear and first lobe as well as same color stripe before the first lobe from opposite end.
This cam was matched up to hydraulic lifters
As indicated above it seams as though the cam was made by or at least sold by MANLEY I'm assuming in the late 1970s at least that's when the engine was last apart to this degree.
Please share with me any info you may have on this cam. Every one tells me that this was the best sounding engine on the street and I really don't want to lose that sound by changing anything and I can't finish rebuilding the heads until I know what to use to match up to the cam. Machinist won't touch them till I know what cam I plan on using.
Old 09-02-2010, 01:21 PM
Send the cam to a custom grinder like Custom Cams or Bullet, or Isky. They can reproduce the cam exactly for about the same price as a flat tappet racing cam.
Old 09-02-2010, 02:06 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
It's a Manley product contact them.
Rich
Manley Performance Products, Inc.
1960 Swarthmore Avenue
Lakewood, NJ 08701
Phone (732) 905-3366
Fax (732) 905-3010
East Coast Manufacturing Plant
Sales Hours 9:00 AM - 5:30 PM EST
(800) 526-1362
sales@manleyperformance.com
Old 09-02-2010, 02:35 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
Originally Posted by waterboy4413
A To get to the point, there is no other cam set up that I want to use. If I can't use this cam then I want to find an exact duplicate. No compromise. So what I'm looking to do is find every spec of information I can on this cam so that I can reference it when finding a replacement. Here is all the info I have to use for Identification:
I'd like to know what it is also. Hope you post when you find out. I understand how you feel about this build.
Old 09-02-2010, 04:24 PM
ericnova72's Avatar
More for Less Racer
This is probably going to be your only chance of getting a replacement, and the easiest way to do it also. Add Mike Jones Camshafts and Jay Allen's Camshaft Innovations to that list.
I realize you didn't ask, but any of the mentioned companies can set you up with a modern cam that will make more power, just because of technological advancement in cam design and manufacturing since the cam you have was originally designed.
Old 09-03-2010, 10:08 AM
I realize you didn't ask, but any of the mentioned companies can set you up with a modern cam that will make more power, just because of technological advancement in cam design and manufacturing since the cam you have was originally designed.[/QUOTE]
I would like to thank everyone for replying so quickly with such useful advice as for the quote above. This rebuild isn't about increasing power by modern advancement. It is purely nostalgic. Every part of this car and engine is exactly restored to the way my father built it up in 1977. I realize I could have gone a long way in making it look the same with a modern reproduction, but this car wasn't all about its look and performance. This thing was notorious for having a sound like none other. A sound that I have yet to find duplicatable. Now that I know what the secret behind the cam is I know why.
I still intend on finding more information on the history and specs of this cam so I will contact Manley to see if any record is still left on their product line from back in the 70s.
Old 09-03-2010, 11:53 AM
Duntov's Avatar
Just like it was.
[/QUOTE]
This rebuild isn't about increasing power by modern advancement. It is purely nostalgic. Every part of this car and engine is exactly restored to the way my father built it up in 1977. [/QUOTE]
Hey again,
I looked through my bookmarks last night, and "saved mail", and couldn't find the guys in Pennsylvania that grind cams, but I'm sure they can install your cam in their cam lathe or some sort of device, turn it and read the specs. If we can do it I know they can. We installed a degree wheel on a dummy block set up years back. Mounted a dial indicator for both intake and ex. Installed lifters on the lobes we read. Turned a degree and took notes. First time we did it, it took all evening..
We did read several in and ex lobes because we assumed wear would throw us off. And they were not all exactly the same but close. We gave them all the separate readings. Emailed them the high average on the specs and called, and they emailed us that afternoon with the grind number. They had it on file.
OK so when we got it back we took the biggest readings we got from every aspect of each lobe(same specs we sent them)... Anything less in another lobe had to be wear. We high averaged all 8 in and all 8 ex. And it read almost exactly like the cam card. We were .002 or .003 short with our average.
We did it for a similar reason . If I can't find these guys I'm sure that some of the shops you were refferred to here, are just as good or better.
If all else fails, you can write Ron Iskendarian at his newsletter and tell him why you have to have it. He's a real normal every day guy who has taken time in the past to do just such things.
Old 09-03-2010, 03:42 PM
topwrench's Avatar
Last journal entry: fish carb
Please tell me u checked the cam timing before u pulled it out.
There is another way to time cam that a lot of peple still use.
If engine sounded just "different" maybe he timed cam "straight up".
This is not just lining up timing marks.
A little more involved than that....
camshaft question crussell85 Engine 21 07-24-2010 09:42 PM
Comp Cams Xtream Energy 268 camshaft chevymastermind Engine 15 05-22-2007 05:15 PM
Rotella Motor Oil boss350 Engine 14 04-17-2007 11:00 PM
1998 Chevy Venture camshaft kberly54 Engine 2 07-14-2005 08:09 PM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 04:04 PM
