Need help removing glue - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2004, 08:14 PM
OldBucsFan's Avatar
I searched the knowledge base with no luck, so here goes. The car I just purchased has tinted windows. The sales sticker was afflixed to a window with tint. When I removed the sticker, some of it (and glue) stayed on the window. What cleaner or solvent can I use to remove the remaining sticker without harming the tint? Any tricks to it?
Thanks
Old 01-25-2004, 08:56 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
3M general purpose adhesive wax and silicon remover. wallyworld has it in automotive, the part # escapes me right now.
a little dab on a rag, some mild rubbing and it ought to be gone, leaving the tint intact.
Old 01-25-2004, 09:30 PM
Gene Neal's Avatar
Glue on tinted window
I have not tried this yet, but was told by a shop that cleans up the car for the Mile Of Cars, Here in San Diego, that they use WD 40 to get the sticker glue off the windows of new and used car's. One never knows what will work. -----------------------------------------Gene Neal
Old 01-26-2004, 08:20 AM
Custom User Text:
Old 01-26-2004, 08:34 AM
WD 40 works.... also look for Goo Gone, comes in a little can like 3 in 1 oil
Old 01-26-2004, 09:40 AM
OldBucsFan's Avatar
Thanks for the tips everyone!
Old 09-01-2004, 12:17 PM
dawn_quixote's Avatar
Place black plastic on the outside of the doorglass, spray ammonia on the inside of the glass over the tint, take a blow dryer is it's below 85 degrees, and heat up the outside of the glass..start at the corners of the tint and just smush it up to the center of the window and remove the tint..should take most of the glue with it, if not spray with ammonia again and wipe until clean..
Old 09-05-2004, 05:25 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
razor blades, windex, and lot's of elbow grease. If you have a shop in your area that sells johnson window films you can pick up some stuff called film off.
Old 09-05-2004, 06:03 PM
Rhansen's Avatar
Footbraker
Oven cleaner also works like a charm. That's how I cleaned the adhesive from my windows.
Old 09-06-2004, 04:30 PM
RodFather's Avatar
I hate to say it but paint thinner will work wonders.....but I would let the car air out before I drive it
