Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help to repair door bottom
Old 11-23-2005, 03:12 PM
OC Joe OC Joe is offline
On my daughters van the door bottoms are rotten and I plan
to put on bottom skins.My question is,after I tack weld along
the top of the skin should I use a seam sealer and then
bondo to finish, or weld solid (I would worry about warping it
if I did that)
Thanks for your help.
