need help ,rochester dualjet - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2011, 01:41 AM
i am jus trying to figure out . which needle is which? i am trying to adjust for mixture .there is a drivers side one and a passenger side one bottom side of carb in front. oh yes and how many turns to adjust each? any help would be hella great. its not the electrical carb either all mechanical
Old 11-09-2011, 02:08 AM
DoubleVision's Avatar
The two screws on the bottom front of the carb is the idle mixture adjustment. No carb has a "set amount" for them. They are set with a vacuum gauge. When the gauge has it`s highest vacuum reading it`s correct.
Afterwards you`ll want to set both sides equally. Do this by turning it in and count the amount of turns until it seats lightly. If you seat it tight it can do damage. Then turn it back out the same amount then follow on the other side. If you don`t have a vacuum gauge then set them to where the engine idles the highest by tachometer and runs the smoothest, if no tach, do so by ear. Turning them in leans the mixture. Turning them out richens the mixture.
Old 11-29-2011, 07:00 PM
thanx , that is very helpful . i was kinda on the rght track but wantd to ask for advice.... gracias amigo
How to properly tune Rochester DualJet 210? Torx Engine 7 06-19-2014 06:16 PM
rochester dualjet help hcker2000 Engine 10 12-27-2007 01:32 PM
How metering rods work in Rochester Dualjet ? Olds 69 Engine 1 02-18-2005 03:56 PM
who knows something about rochester dualjet 210 carbuerator diAMID Engine 0 09-14-2004 03:36 AM
rochester dualjet 210 oakland_raiders Engine 4 01-03-2003 08:58 PM
