Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with rocker/lifted noise
Old 09-03-2012, 01:43 PM
350chevyrob's Avatar
350chevyrob 350chevyrob is offline
haulin ***** and suckin gass
I used to pretty quiet .but i have been racing it a lil ...it still builds great power but its only that one at as been ticking the other side of the engine sounds fine ..but you mite be right.i mite have a spec of crud in the lifter.i did notice when i have the valve cover off running the engine that one of the rockers didn't fill up oil as much as the others were ..so i thinking i should pull out that lifter and clean it or just change the oil with something thicker
