need help sanding closed cell foam. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2007, 02:30 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I have 1/4" closed cell foam (landau foam). What do you guys use to sand this when finishing the edges?
Thanks,
Old 04-25-2007, 04:08 PM
AllSteel34's Avatar
A die grinder with a 36 grit disc works well. I've shaped seat foam this way. For rougher bulk shaping, an electric meat knife is good, but for edge cleanup it probably isn't the best choice.
Chris
Old 04-25-2007, 04:19 PM
DanTwoLakes's Avatar
Wiki Edits: 22
If you're scuffing before gluing or finishing edges, use Scotch Brite industrial pads. They come in different degrees of coarseness and are color coded. From heaviest to lightest they are tan, gray, maroon, light gray, and white. The maroon is a general purpose pad that should work fine for you.
Old 04-26-2007, 06:51 AM
RodFather's Avatar
Thanks guys.
How Much Foam to put in a Fuel Cell??? texastomeh General Rodding Tech 1 11-28-2006 11:05 AM
Fuel Cell Foam or not Scoops Engine 2 01-23-2006 04:39 PM
fuel cell foam Vortech 4.3 Engine 6 12-27-2005 07:42 AM
closed cell foam/sculpting vintage Interior 0 04-21-2002 04:23 AM
