Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help sanding closed cell foam.
Old 04-25-2007, 05:19 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
If you're scuffing before gluing or finishing edges, use Scotch Brite industrial pads. They come in different degrees of coarseness and are color coded. From heaviest to lightest they are tan, gray, maroon, light gray, and white. The maroon is a general purpose pad that should work fine for you.
