Need help with SBC cam install (timing marks question) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2011, 01:48 PM
Zeeb's Avatar
In the disassembly phase and I'm noticing something strange with my timing marks. At TDC on cyl. #1 on the compression stroke, the cam gear "dot" is at 12:00 (not 6:00 as it should be). The crank gear "0" is at 12:00 (good). Cam dowel is at 9:00. Distributor rotor at #1. Engine ran fine like this. I have a new Crane cam ready to go in, but I'm concerned, because I had expected Cyl. 1 to "hit" when the cam gear timing mark was at 6:00, and one of my books mentions the dowel at 3:00 (not 9:00). Any idea what gives? This is my firs cam job, and every photo I have seen shows the cam mark at 6:00 and crank at 12:00. The engine was rebuilt. Builder cannot be reached. I can certainly duplicate this setup using the new cam, and it seems I would have to if I expect the engine to run. Advice appreciated. Thanks!
Old 02-20-2011, 02:01 PM
ericnova72's Avatar
More for Less Racer
It is correct as you took it apart. With the cam gear at 12:00 and the crank gear at 12:00 you are at TDC firing #1 cylinder. With cam gear at 6:00 and crank gear at 12:00 (as recommended for ease of aligment at assembly) you are at TDC exhaust stroke on cylinder #1...and you are actually at TDC firing #6 (1/2 way around the firing order).
Dots aligned at 6:00 and 12:00 is not TDC firing #1, it is just for cam to crank assembly. If you drop the distributor in the engine at this time pointed at #1 cylinder on the cap you have just installed the distributor 180 out of alignment. This fact trips up a lot of inexperienced mechanics who assume thet cam and crank dots aligned = TDC firing #1...it doesn't... it is really TDC firing #6.
You have to seperate cam to crank timing from distributor timing in this case.
Old 02-20-2011, 02:02 PM
BOBCRMAN@aol.com's Avatar
The cam runs at 1/2 speed. Every other revolution cam is at 6 and crank is at 12 or the cam is at 12 and the crank is at 12. It makes no difference when assembling. Cam can be at 6 or 12..
Old 02-20-2011, 05:14 PM
ZEEB, having the crankshaft at #1 TDC is insignificant. You are aligning the camshaft with the crankshaft. Just put the crankshaft gear dot at 12 oclock and then the camshaft gear dot at 6 oclock. Install the timing gear set and you are good.
Old 02-20-2011, 07:41 PM
Zeeb's Avatar
Got it guys! Thanks. You really helped out.
Old 02-20-2011, 07:57 PM
Madmax305's Avatar
Not trying to hijack this thread, but where does he install the distrubutor for it to be in correct firing order on the start up?
Old 02-20-2011, 08:50 PM
12 and 12 .alot of people make same mistake including me many moons ago.
Old 02-20-2011, 09:01 PM
Zeeb's Avatar
Although I haven't progressed to that point in the job, I think I understand. Once I line up the timig marks with cam gear mark at 6:00 and crank gear at 12:00 and torque the timing gear bolts, I'll place my finger over cyl. #1 and find the compression stroke, also observing both valves closed. At TDC on #1 cyl. compression stroke, cam gear mark and crank gear mark will both be at 12:00. I'll drop in the distributor and adjust it to align whatever "tower" I want to call #1 to meet the rotor in its current position. Which is the "fire 1" position at this moment. Once #1 is determined, just fill in the rest of the wires in the proper order.
Old 02-20-2011, 09:31 PM
ericnova72's Avatar
More for Less Racer
You are absolutely correct
You won't really need to do the thumb over the hole find compression trick. With the crank gear at 12:00 and the cam gear at 6:00 after you have installed the timing set,... all you need to do is turn the crank one full revolution, which will put the cam gear at 12:00 and crank gear back at 12:00(and the engine at TDC firing #1 cylinder) and you can then install the distributor just as you have outlined.
Old 02-20-2011, 09:53 PM
Madmax305's Avatar
OK, it makes sense now...
Timing marks question HDThunder Engine 17 12-11-2010 10:30 AM
351W Timing marks & 408 clearance question eric866121 Engine 5 07-05-2009 02:51 PM
timing cover install question sexypizzaman Engine 6 11-06-2008 07:01 PM
SBC front timing cover install question v8hed Engine 5 07-26-2008 12:04 AM
350 timing marks johndoe Engine 4 05-04-2004 10:30 AM
