need help with self energizing braks - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 01:52 PM
need help finding self energizing brakes that will fit a 48 ford passenger car front spindles, i have heard something about buick brake what need to be done to the backing plate to make it fit this is all new to me im hopeing some one know's what to do, i have ben a part's changer most of the time this is my frist try at a 51 ford pickup rat rod thanks #1spudman
Old 02-23-2012, 02:25 PM
From what I remember Lincoln Zepher brakes are self energizing and the only brakes that bolt on your spindles. They were the hot rod brake for years and years on the early V8 Fords.
Old 02-24-2012, 03:19 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try speedway motors as they have a lot of pieces for early fords. the lincoln brakes are in short supply these days..
Sam
Old 02-24-2012, 05:33 PM
Wiki Edits: 49
I responded to your PM with the link you asked for.
The do it yourself method I used can be done by using your stock backing plates and hubs. There is a mod you'll need to do to the backing plates but if you have a welder that part is easy. Then you just need the innards from your choice of modern brakes that are the same size as you're stock drums. That's pretty much it.
The Lincoln brakes and the stuff from Speedway will cost you a bit of cash. If you do it yourself it'll cost you a couple junk backing plates, brake shoes and kit from Napa, and some new wheel studs (providing you want to convert to slip on brake drums). Probably less than a hundred bucks.
Centerline
HotRodsAndHemis.com
"Speed has never killed anyone, suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Old 02-25-2012, 07:31 AM
thank you so much
thank's so much centerline that help so much im on a low budget build and front brake's has ben driveing me up the wall im not good at coming up with idea of my own i have ben a parts changer for a long time i can do the work i just need the how to first i have adhd and have ben put down for it all my life thank you so much for all your help GOD bless you
Old 02-25-2012, 10:10 AM
Yeah for goodness sakes do it like a hotrodder! I just got a new Speedway catalog in the mail (don't remember ever buying anything from them so I don't know why I keep getting them) and my God it's CRAZY what is available. And I mean CRAZY because people go to catalogs like this and it is an inch away from building a "kit car" using stuff like this, GEEEEZ, they make EVERYTHING (mostly in China). I understand someone could build a complete car on their own and just buy one piece from them, but I can see the guy with boxes from Speedway coming everyday, "geeeez what a waste of good machinery" Click here if you don't know what this is from.
Old 02-26-2012, 08:40 AM
thank's
thank's brian and all of you for all the help and encouragement that you give
need to have someone to come up with a book or dvd were to find part's and idea's what will work together were to find interchange book's the frist big help i found was dvd by back from the dead a full rat rod built by IAN Roussel then a dvd streetrod 101 by BOB Hamilton they gave me lot of idea's and now the hotrodders bullders board now who know's some day maybe ican help someone too thank's for all the help and encouragement mel
GM self-energizing brakes for early Fords Centerline Suspension - Brakes - Steering 1 06-23-2008 10:40 PM
