Need Help in setting distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2012, 06:41 AM
I have a ht383e stroker. I had to remove the heads and noticed heavy black carbon on my plugs. It is a vortec engine with a cam sensor. I can not use the cam sensor since my computer is for a 95 non vortec which does not have hookups for the cam sensor. My question is do I find 0 deg. tdc by putting the groove on the harmonic balancer directly below the sensor? I want to be sure I am not A tooth off when reinstalling the distributor. There isn't any way to put a degree indicator on the front of the engine.
Jeramiah
Old 08-10-2012, 12:35 AM
sat
1 black soot on plugs is a rich condition.
2 you certainly have a good question!
putting a TDC scribe line on a dampener
that has never had one.
guess you could put a dial indicator on top
of block cyl #1 and run it up and down equal
and in between is TDC.
like .10" piston on way up and .10" piston on way down.
put pencil marks at these two and then permanent mark in between.
have a nice day!
Old 08-10-2012, 07:24 AM
Thanks, The engine is in the truck so I will have a hard time using a dial indicator. But a great idea for future reference.
Jeramiah
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
Distributor has a tube running along side of the distributor? sscardino Hotrodding Basics 17 01-18-2012 07:25 PM
Confused over setting up my MSD distributor Irelands child Electrical 23 06-24-2011 06:09 PM
Setting Distributor S10 Racer Engine 12 05-10-2009 08:03 AM
Setting timing:TBI BB V8 Type 2 distributor?? 6x6er Engine 4 02-05-2008 09:18 PM
