The gear vender should have the information you need, keep in mind the tire size comes into play as well.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
I'll post a speedo calc. TCI had a great one and of course took it off their website. This one is okay even though its a Ford site.
I dont know if you have a 7 or 8 tooth drive gear, and you cant just count the 'threads.' You have to lay them flat on their face to count them. So If it was me, I would calculate for both and then pick a driven gear thats between both answers. You'll need your tire height, rear axle ratio and 7 or 8 tooth for a drive gear http://www.moldyrabbit.com/liquid/speedo_gear.html |
I've used a GPS unit instead of a speedometer. It also keeps track of how far I've driven just like having a working odometer.
It doesn't work to well in tunnels. |
Geeees.
Since CompCams took over they've been redoing the TCI site. Leave it to the Bone Heads to screw up a perfectly good working site, can't find squat on there now. Good sites for TH350 gears: http://novaresource.org/speedo.htm http://www.transmissioncenter.net/sp...____va.htm#350 If your Rear Diff is Open/Non-Posi. Jack up 1 wheel and spin 2 revolutions, count the Driveshaft revolutions. For Posi. Jack up Rear and spin both wheels 1 Rev and count DS Revs. = Rear Diff Ratio |
