Or is that little EYEtalian (with a name like Padavano I can say that...) car too light? |
Yeah it lifts the whole car. I considered running a strap around the jack, and looping it around the top of the upper spring recess. I would like to avoid killing myself while doing this so I figured I would try to come up with a better alternative. Headed to autozone now to see if I can find some bolts.
If you have a large enough hole at the top of the spring/shock tower maybe something like this would help. I used an internal spring compressor and set the threaded end aside along with the threaded shaft that came with it. Using a 1/2 threadall I cut it in half and welded a nut on one end. Using a few large washers between the welded on nut and the bottom part or "hole" end of the spring compressor and a couple of large washers on top of the shock tower,,, that probably would make more sense if I posted a couple of pics,,
![]() EDIT: If you try this be sure to use plenty of antiseize |
I thought about something like that. I'd be a little concerned that most all-thread is low-grade steel and not terribly strong in tension. Probably equivalent to a Grade 3 bolt.
Well I got it! The long bolts along with the floor jack did it. I simply, put the bolts through the arm and pan, sat the spring and rubber pieces in and slowly but surely jacked the pan up and tighten the bolts every few compressions. once properly seated I replaced the bolts with the proper ones. Voila!
PS: Oh and it helps if you get your wife to sit on the front of the car. LOL. Sorry honey, thanks for sacrificing pride in the interest of mechanics. |
| Model "A" rear spring | scott3151 | Suspension - Brakes - Steering | 5 | 10-24-2006 08:34 PM |
| measureing spring install height | J327HO | Engine | 1 | 10-27-2004 07:08 AM |
| Valve Spring Remove And Install Help! | Angelshock23 | Engine | 9 | 09-27-2004 02:23 PM |
| front end popping | maddmaxx | Suspension - Brakes - Steering | 4 | 11-15-2003 08:24 PM |
| Proper throttle spring placement | willys36@aol.com | Engine | 1 | 11-13-2002 07:19 PM |
