Need help straightening van floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2007, 09:28 PM
lon77's Avatar
I bought an 88 Astro today with the intentions of fixing it and using it for my work van. I bought it wrecked but not bad enough that it is undrivable. The wreck folded the floor and pushed in the doors. I have another Astro that I can get for free so I have all the parts to fix this one. So how do I straighten out the damaged floor?
My options are:
Bury a steel pipe in concrete with a ring welded to it and use it with a com-a-long to pull out the damaged area.
Weld a piece of steel between the frame rails and use a bottle jack (I can dismantle my press and use it's 12 ton jack) to push out the damaged area.
Do either of the above and cut out the area after it is reasonably straight and replace it with the floor of my donor van. Not the whole floor just the damaged area.
My plans after fixing the crash damage are to do a V8 swap and add a middle seat. This will be my work, family and parts chaser van with some light towing in its future.
Name:	tn_Work Van 006.jpg
ID:	17675   Click image for larger version
Name:	tn_Work Van 007.jpg
Old 01-15-2007, 09:47 PM
BigMike
Use a comalong, attach it to anything you can to get a good pull. use a big hammer and beat down then dents. you might not get enough pulling power on it to pull it out. i work in a body shop and to pull somthing like that out it can take up to 5000 lbs of force. pull it out all the way before cutting it apart. if you dont do that it could spring apart and we dont want that to happen. i hope you can do it with a comalong. well good luck. Mike
Old 01-16-2007, 12:21 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
How much clearance ya got on the underside? Some pics of the underside would help and pics of the inside without the mat probably wouldnt hurt
Just guessing, youll need to straighten it as much as possible then cut it out & replace, since ya have a donor vehicle.
Old 01-16-2007, 01:38 AM
lon77's Avatar
I have come to the conclusion that straightening then cutting out the damaged area is what I will do. I 've been asking around anywhere I think I can get an answer and that seems to be the best way to do it. As soon as the donor van follows me home and I get my other truck running I'm going to start working on it. I asked today about driving a crashed van for work and my manager told me my next truck inspection is due in six months, so I have a little more time than I thought.
I plan to use the donor van for measurements before amy cutting is done and usining temporary bracing when I cut apart the wrecked van. It does not have to be perfect just functional. I rarely sell my trucks so I will be the only one driving this thing for a long time.
Name:	tn_Work Van 003.jpg
ID:	17754   Click image for larger version
Name:	tn_Work Van 010.jpg
ID:	17755   Click image for larger version
Name:	tn_Work Van 011.jpg
ID:	17756   Click image for larger version
Name:	tn_Work Van 012.jpg
Old 01-16-2007, 05:23 AM
adtkart@aol.com
Looke to me like you need to do more than just pull the floor back. The doors are overlapping at the bottom and open on the top. That means that the sides are pulled together. That's one of those jobs that needs a pull from 3 directions at the same time. You need to pull/push the sides out at the same time you are pulling/pushing to the rear.
Aaron
Old 01-16-2007, 08:22 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Did the roof buckle anywhere?
How does the side door and front doors fit.open.close?
Old 01-16-2007, 08:38 AM
ckucia's Avatar
I have no experience with fixing collision damage, but I have a question...
Rather than trying to pull the floor back close to shape, then replacing it, wouldn't it be easier to cut out the floor first, then pull the remaining parts into shape, then replace it?
Seems like its a lot of extra work and force to try and stretch that floor back into shape, if you're just going to replace it anyhow.
Maybe I'm missing something - that's why I'm askin'...
Old 01-16-2007, 08:51 AM
ckucia, IF he had access to a REAL frame rack, in a regular body shop you WOULD pull before you cut away parts. This is standard procedure in autobody 101. It pulls on secondary damage and helps you make a more "complete" repair.
HOWEVER, if you don't have a frame rack, a come-a-long just is NOT going to pull the type of damage seen in these photos. So, cutting out the center of the floor, pushing the rails apart at the rear until the bumper reinforcement fits, AND the replacement doors are installed and fit makes sense.
You then weld in the rear crossmember and then the floor. You know, in this country we are so spoiled. In many third world countries we wouldn't even think of buying another floor, new or used. That floor would be cut out, the frame repaired as I described, and the floor repaired, then welded back in.
Even the rear crossmember would be repaired and welded back in. But that takes a lot of craftsmenship to pull off.
This van being repaired at home without a real frame rack is going to have a few "rough" spots. But it can be made to function well again and be presentable.
Old 01-16-2007, 10:50 AM
ckucia's Avatar
Thanks, Brian.
Old 01-16-2007, 11:54 AM
lon77's Avatar
adtkart: The rear rails are pushed in I plan to push them out again and use the measurements off the donor van as a guide. When they are straight I will weld in a temporary brace, until the crossmember is in solid.
Rambo: The roof did not buckle, if the van had been damaged any where else I would not have bought it because I dont want to get into cosmetic repairs. The donor van is white and I dont plan to paint the new doors or front fender. This will be a circus wagon for a short time.
Brian: You caught me! Yeah I posted this question on another site. Spoiled??? Yeah I guess so. I can get on the net and ask complete strangers for help. And get free or nearly free parts. But I still have to do the labor.
Old 01-16-2007, 01:48 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
is the donor van in better shape than this van?
Old 01-16-2007, 05:06 PM
lon77's Avatar
Yes unfortnately. But it is a cargo van and I want a window van. This van has the seat mounts for the middle seat. The donor van's engine trans and rear are not complete. The only thing worth while on it is the body. Some day I want to put a mid engine big block in the donor van. I know it seems like a waste to cut it up but it was about to be crushed.
Old 01-16-2007, 07:08 PM
it would prob be easier to just swap running gear into the better body....?
but you want windows so i can see why that wont work but still...lol
Old 01-16-2007, 09:29 PM
lon77's Avatar
Yeah I got to have windows. My current family ride is a S-10 extended cab. My daughter sits sideways and looks out the drivers side of the truck. It is time she gets a better viewe. And I cant stand how conversion van windows look. Also I dont want a car payment but I want an Astro window van so it may not be easy but it is cheaper.
The wrecked van runs pretty good and the donor doesnt run at all. I'm down to one vehicle until I get the new motor and air compressor installed in my fullsize GMC, it is on airride and the compressor sucked in some dirt. Dirt + Compressor Motor = Dead Compressor. As for the engine, well I killed it. On a side note for those with airride. Find a way to put a manual fill valve in your lines. Moving a grounded truck is no fun.
Lon
Old 01-16-2007, 09:33 PM
colormecrazy's Avatar
Paintshop Dog
I'm so very sorry!
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 09:33 AM
floor fabrication johnnymopar Body - Exterior 2 03-13-2006 08:00 PM
starting the floor modas Body - Exterior 1 07-17-2005 07:39 PM
Once again.....JOKE TIME!!!! RCastle Hotrodders' Lounge 41 01-21-2005 02:27 PM
Try this on the wife Gr8 '48 bow tie Hotrodders' Lounge 3 09-18-2002 02:04 PM
