CKL 1973 350 tur hydro, Calif - F A B
CKL 1975 262 - Nova/Chevelle/Monte
Since you already know it`s a 350, apparently it came out of a F A or B body. The date code will be on the rear of the block on the bellhousing. It will look like this example: C 15 3 which breaks down into:
C the month, C is March, A is Jan, B is Feb. Etc.
15 is the day, the 15th of march.
3 The year 1973. if the date code varies by many years than the info given in the suffix code it could be a suffix that hasn`t been recorded yet.
While it`s true the 336 castings were used only in 71, you`d have to be sure the heads came factory on the block.
F indicates Flint Engine Plant.
02 indicates the month of Feb.
19 Is the 19th of that month.
