Need help taming the Model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 10:50 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
We are now "tweaking" the 28 hot rod we are building for my son.
On a hard takeoff (read that as, smoking rubber - balls to the wall) the rear end squats and torques over so far the tires rub on the body. Its a 4 bar rear end setup (oldguy829 journal has pics) with coil overs. there really isn't anything there to stop the torque. Any suggestions? Sway bar?
thanks guys
Old 03-08-2007, 05:45 PM
BOBCRMAN@aol.com's Avatar
You do have a Panhard bar ? right. This should keep the rear centered. If not, adjust it so the body sets just a bit off. To clear the tire under hard acc.
Old 03-08-2007, 06:32 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
There is nothing particularly bad with your suspension set up. The squat and roll is part of the parallel-4-bar design.
A real anti-roll bar would help.
Too bad BillyShope doesn't show up, he is THE expert.
Where's Billy Shope ??
http://www.hotrodders.com/forum/members/billyshope.html
You might cruise his site for help=
http://home.earthlink.net/~whshope/
Model A Factory Tour Pics... moefuzz Hotrodders' Lounge 6 09-16-2010 08:48 PM
Are all Model A chassis the same? HotRodKush General Rodding Tech 12 03-16-2010 08:05 AM
Model T Frame adtkart Suspension - Brakes - Steering 19 01-07-2008 09:53 PM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
confusing question about cars and their weight stonedchihuahua General Rodding Tech 14 03-27-2003 03:00 PM
