Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with temp and oil pressure gauge
Old 06-09-2012, 02:24 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
temp senders can be tested on the bench immersed in a cup of boiling water hooked up to a multimeter using ohms for resistance. The meter will change as the temp drops if the sender is ok.
