Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with temp and oil pressure gauge
Old 06-30-2012, 12:21 AM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Originally Posted by 0pyders View Post
fixed oil pressure gauge with new sending unit.
replaced temperature gauge and all is fixed now.
Thanks for the tips 67Mustang Al.
Your welcome. Glad to be of help.I have had plenty of help on this site. What goes around comes around. Its great when you can fix it yourself. Better to have the cash in your pocket .
I had a case on my Mustang with the fuel gauge, oil pressure gauge and temp gauge all working for 5 minutes on, then 15off, then 5 on, then off again.
AS these gauges are 6v in a 12 volt system i used an electronic 12v to 6v electronic regulator to run 3 gauges. You need 1 electronic reculator per gauge. The reg would heat up and cut out under overload, cool down and then function normally again.
Bootom line; 1 reg per 6v gauge for old Mustangs with 6v gauges.
