Need help with temp and oil pressure gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2012, 10:49 PM
0pyders's Avatar
It's a 1986 Firebird.
Oil pressure gauge: With key on, it doesn't blip to max then back to zero. When I start the car it always goes to 60 psi and stays there.
-with IGN on, I can get the needle to max when I disconnect sender wire.
-IGN on and sender wire grounded to negative battery it stays at 0.
Temp gauge: ign on, it never blips to max then back to 100. When I'm letting it warm up in park, I can see the gauge start to move higher a little bit (like it's working fine), then whenever I hit the brakes the needle goes straight to zero.
-can't get gauge to max when sender wire is disconnected.
-gauge stays at the bottom when grounded (100 degrees)
The rest of the gauges work fine.
I don't know what to do next.
Old 06-09-2012, 03:14 AM
67Mustang Al.'s Avatar
I would try an extra earth wire from the gauges to chassis somewhere . If the senders in the engine block/head meter out ok when tested then it has to be the end of the gauges.
Al.
Old 06-09-2012, 03:24 AM
temp senders can be tested on the bench immersed in a cup of boiling water hooked up to a multimeter using ohms for resistance. The meter will change as the temp drops if the sender is ok.
Al
Old 06-29-2012, 08:05 PM
0pyders's Avatar
fixed oil pressure gauge with new sending unit.
replaced temperature gauge and all is fixed now.
Thanks for the tips 67Mustang Al.
Old 06-30-2012, 01:21 AM
Your welcome. Glad to be of help.I have had plenty of help on this site. What goes around comes around. Its great when you can fix it yourself. Better to have the cash in your pocket .
I had a case on my Mustang with the fuel gauge, oil pressure gauge and temp gauge all working for 5 minutes on, then 15off, then 5 on, then off again.
AS these gauges are 6v in a 12 volt system i used an electronic 12v to 6v electronic regulator to run 3 gauges. You need 1 electronic reculator per gauge. The reg would heat up and cut out under overload, cool down and then function normally again.
Bootom line; 1 reg per 6v gauge for old Mustangs with 6v gauges.
Cheers.
Al.
oil temp gauge instead of trans temp gauge mocheez Electrical 8 01-01-2012 02:02 PM
Oil and temp gauge hook up? truckboy61 Engine 7 07-11-2010 11:20 PM
Temp, Oil and gas gauge pegged. lazydawg Electrical 1 10-08-2009 06:51 PM
Adding pressure/temp gauge for T-350 firebirder Transmission - Rearend 8 07-10-2009 07:38 AM
oil temp gauge fiscus Engine 7 10-21-2007 02:09 PM
