Need help with TH350 back-up light switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 06:26 PM
Okay, I'll admit to complete ignorance here,so please be kind and gentle.
I'm modifying my dash and currently the back-up lights are directed by a toggle switch on the dash,rather than the usual switch engaged on the transmission when shifting. I want to more the switch the the transmission location and eliminate the toggle. I have NO idea how to do this.
I've seen the switches from Lokar and Ron Francis, but I really don't see how to mount them,or engage them or anything else. Really stupid,huh? So could someone kindly post or send me a diagram,.photograph,drawing,extended explanation or an online reference on how to do this? The spring Carlisle PA meet is coming up and I'm hoping to figure out what parts I need before the show. Thanks. Jeff
Old 04-04-2006, 09:26 PM
Jmark's Avatar
The TH350 did not have a place for the backup lights, they were controlled by a switch on the column under the dash, usually intagrated with the ign. switch.
Mark
Old 04-04-2006, 09:58 PM
Crosley's Avatar
Wiki Edits: 1659
I believe a few good answers are on your thread on the HAMB board.
Old 04-05-2006, 05:27 AM
"I believe a few good answers are on your thread on the HAMB board."
True-but it's always nice to get a second opinion and who knows who might post the answer I need, so I like to cross-post. You can also count on the HAMB to post a few jousts and critical comments-I know because I join in myself. I appreciate everyone's help and hope I can return the favor sometime.
Old 04-05-2006, 06:02 AM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
1) Do you have a colunm shift? or floor shift?
This will dictate where your back up light switch will be mounted.
My car had a colunm shift and now has a Hurst floor shifter with the switch added to the floor shifter.
Old 04-05-2006, 08:43 AM
I've got a column sift-the column is out of a Chrysler, probably late 70's with a tilting and telescoping wheel.Called the Tilt-n-scope, it's actually GM technology leased by Chrysler with just enough twists added to make it exciting.
Old 04-05-2006, 09:11 AM
Jmark's Avatar
Ok, I'll bite, whats the "HAMB" board? LOL
Old 04-05-2006, 12:51 PM
The HAMB is a parallel site to hotrodders. Quite a bit more irreverent,devoted to traditional hotrodding-you'll need a tough skin to participate but a good bunch of folks deep down. Here it is:
www.jalopyjournal.com - named the HAMB because Ryan the moderator apparently said he wouldn't run no Hokey *** Message Board
See, on the HAMB,I could say "***".
Old 04-05-2006, 08:31 PM
58Chev's Avatar
Within the column there is a NSS (Neutral Safety Switch), this switch controls your reverse lights when you shift into R.
http://store.summitracing.com/egnsea...2&autoview=sku
Ron Francis also carries a variety of options.
You might need to just replace the switch in the column or the wiring has not been hooked up. Since this is not the original column.
backup light switch location 19nova72 Transmission - Rearend 2 07-11-2005 08:23 PM
Overhead Courtsey Light Only Has Dime Glow JohnTN Electrical 3 06-07-2005 03:48 PM
72 camino light switch knob Scuzzy Interior 3 03-21-2004 07:01 PM
Ford Light Switch....Please Help. Coleman396 Electrical 1 11-16-2003 01:35 AM
