need help with timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 04:17 PM
prettyboyced's Avatar
i have a 90s blocks with 193 heads shorty heads 270 magnum cam edelbrock intake and carb 3.73 gears stock hei dist. ok i tried 32 total and its a dog so i turned it to 40 total and its waking up so i was wonder should i keep going advancing timing or is something else wrong
Old 06-28-2010, 04:54 PM
I don't know what type of heads you got and I am assuming its a 350 sbc. With that cam somewhere between 12-18 degrees initial timing with vacuum advance unhooked and 34 to 36 mechanical all in by 2500-3000 rpm would be ideal but all motors are different depending on other factors but that would be the ball park numbers anyways.
Also make sure you hook your vacuum advance up to full manifold vacuum and make sure its an adjustable one and limit it to around 12 degrees total. You might want to check out your distributor and make sure the weights are not sticking and its working good. Also check your coil and make sure its firing good.
Also if you got old factory gm smog type heads and if you got only around 8 to 8:5 to 1 compression that does not help. With that cam you need some good flowing cylinder heads and your carburetor will need to be tuned as well. Give some more info as what carburetor you got and is your intake a edelbrock performer or the performer rpm?
I am certain others will help you out too. The more ideas posted on what to check will help.
Eric
Old 06-28-2010, 05:54 PM
i have tbi heads 65cc and just reg performer and 600 edelbrock carb
Old 06-28-2010, 07:16 PM
Well from reading on other threads on here the TPI heads are one of the worst flowing heads from GM. That is part of your problem not much power. It takes a decent amount of torque and some decent horsepower to make a car take off really fast and have excellent response.
My brother has a 88 chevy caprice with a stock 305 and it makes only about 175 horse power and somewhere around 250 ftlbs of torque or a little more and it does not run fast at all compared to something with more power. With that bigger cam it's more then what your cylinder heads can really handle.
You have basically over camed your motor. Why do I know this? Because I like many first timers have done this sort of thing. I once had a bone stock 350 with poor flowing 882 cylinder heads and a comp cam 292 magnum for a cam. That thing sound good but that was about it. It had poor throttle response and nothing on top end.
All parts have to match within a certain area for it all to work good. What you need is a cylinder head upgrade and keep your current carb nothing wrong with it. If you got a set of after market heads with 180cc intake runners and maybe switched out the performer for the rpm performer it would really wake up your ride.
I know if you don't got the funds that is not an option. At least get your heads ported and the exhaust ports opened up that would help some.
Old 06-30-2010, 05:30 PM
i think i found my problems i thought i had -12cc pistons but found out that the motor is HD and its 4 bolt main -18cc and 64 cc heads so compression is 8.75:1 so i was wonder can i mill the vortecs to 58cc
Old 07-01-2010, 07:34 AM
texas97z's Avatar
Last journal entry: A little progress and maybe new paint
6 cc's is a lot to try and shave off flat mill, but it depends on the amount of material on your heads. Best bet would be to take to your maching shop and discuss options.
Another idea for getting compression up would be to angle mill the heads. I just had this done on my main car. You will also have to get the intake done(would anyway with the amount of flat milling you were looking at) and do a little work possibly to get the headers to fit right, but well worth it. They rolled my heads 2s from factory 23 and my combustion chambers went from 58 to 46.5cc.I opened them back up after that but you get the idea. Angle milling will get you there, just takes more work. Plus rolling the valves more center over the cylinder is not a bad thing either.
Josh
Old 07-01-2010, 08:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Those swirl port heads won't rev, but down low in the RPM range they will pull.
The reason turning the timing to 40 helped, isn't the 40 total, it's the increase in the initial timing that's helping.
So, what you need to do is run more initial, w/o going over about 36 total. This might mean modifying the distributor to limit the mechanical advance.
This is a rough guideline of how you can set up your distributor, tune it from this baseline for the best performance:
About 34-36 BTDC total, all in by about 2500 RPM (this is adjusted by the springs), with about 10-12 of vacuum advance. See where this leaves you as far as initial timing. You'd like there to be at least 14 BTDC at idle speed, more will likely be needed, but start lower and add timing, not vice versa. Be sure as you add initial timing that you do not exceed the 34-36 total timing. Connect the vacuum advance to a manifold vacuum source.
Be sure you readjust the carb idle mixture screws as you change the timing. If you were not using manifold vacuum for the vacuum advance, you will get an increase in idle speed when you hook up to manifold vacuum. Use the curb idle screw to lower the idle speed.
If needed, there are adjustable vacuum cans like the ACCEL #31035. It's an adjustable vacuum advance can for the GM HEI that allows infinite adjustment to BOTH the amount and rate of advance. Comes w/instructions and tool.
If you find the can is OK but has too much advance, you will need to physically limit the vac can's travel w/a VACUUM ADVANCE LIMITER PLATE- Crane #99619-1; #99619-1 INSTRUCTIONS.
If you're unsure, or just want to check the accuracy of the tab/mark for TDC, DETERMINE TDC will help you to see for yourself.
You can use MAKE A TIMING TAPE for instructions on making a temporary timing tape to use to check/set the total advance if you don't have a dial back timing light. Before removing the tape, permanently mark the damper w/the total advance position and any other positions you want.
Good luck.
Old 07-01-2010, 08:39 AM
Center Bolt heads
The 193 heads are mid-80s center bolt smogger heads. Those are among the most restrictive of the SB Chevy heads and are not any good for performance use. Maybe the trick milling and rolling as suggested would improve those heads. However, before I would go to all that trouble, it seems to me it would be better to find some better heads to start with.
I have not been searching for rebuildable SB V8 iron heads lately so I don't know how difficult it is to find the good ones. They are like all GM high performance heads and the good iron heads have been rebuilt to death. It may be time for you to purchase some new aftermarket aluminum heads rather than tie up a wad of cash in the 193 heads.
Old 07-01-2010, 02:47 PM
today in class one of my teachers brought up that back in the day he use to use 305 heads on his 350 and would boost his compression and torque but run out of power around 5K and i have a set of 601 heads on my other motor i was wondering since both heads run out of power about the same and the 601 will give me better compression would it be worth it
Old 07-01-2010, 04:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Casting number 14022601 were used on 267ci and 305ci engines from about '79-'86. They had either 1.72" or 1.84" x 1.50" valves and the chambers were about 58cc. So the compression ratio would be higher. But if they have the 1.72" intakes, no way. Even the 1.84" valves are down in size for what you need to let the cam work at higher RPM's.
Overall, it's probably a wash between the two heads, the TBI heads better down low, the 601 maybe a little better higher up, w/no guarantees that will hold true, given the intake valve and port size.
Either head will be down a considerable amount of power from Vortec heads.
Old 07-01-2010, 09:46 PM
texas97z's Avatar
I am 4-5 hrs north of you, but I have a set of none tbi heads you can have. They would need quite a bit of work as they are "Hecho en Mexico" with 76cc chambers and all. But for $60 in gas, might be worth it. I don't know if your school (SAM?) has a maching class (If SAM I know they do), but the shop I use only charges me $45 per head and $45 for the intake to angle mill them. These heads have a lot of deck surface so milling should be no problem. Plus the valves are 1.94/1.50.
You would still have $200 plus valves and springs in them with gas money. I agree with cobalt in the vortec heads are a good choice. Valves can be had on ebay brand new for $80, springs depending on cam needs, $55-$150. So atleast $350 for "free" heads to do what you need of them. Might not be too far off from those vortec heads.
but the offer is on the table if you want them.
Josh
Old 07-02-2010, 01:03 PM
i can probably get some vortec heads in a couple of months so should i keep the tbi heads on or put the 601 heads on there till i get the money for the vortec heads and intake
Old 07-03-2010, 01:24 PM
i found some heads L98 corvetter heads ready to bolt on for 150
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 01:35 PM
sbc timing question 350pano Engine 8 05-15-2009 11:30 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 06:47 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 01:51 PM
