Need Help - Which Torque Converter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2005, 08:55 AM
Need some help! I have a 68 camaro, 350 engine (430 hp, 430 torque), th350 transmission, 373 posi rear. I am not sure which torque converter to put in. I was told a 9" converter with 2800 stall but I do not know much about converters. If anyone can help me out or make any suggestions it would be appreciated! Thanks. The car is NOT a daily driver. It is basically a street/strip car.
Old 04-11-2005, 10:52 AM
Max Keith's Avatar
which converter?
A big question at this point is what is the power band of your camshaft?
That is a big part of choosing your TC.
Other factors are, what type of tire are you required to run, or allowed to run.
If you are having to run a street tire, or a street legal racing tire, you might want to consider going with a TC that stalls at about 500 RPM below the power band of your camshaft.
If you are able to run super sticky, down and nasty, all out drag tires, then you might want to go with a converter that stalls at about 500 RPM above the bottom of your power curve.
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 11:08 AM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 02:57 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 05:21 AM
