need help on tranny info - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2002, 07:20 PM
Post need help on tranny info
i broke my tranny then i sent it into a tranny shop to get it fixed but they did not fix it prop because when i went underneath the truck i could push up and down on my drive shaft does that mean turbo 400 have diff sized splines.but the tranny i had was a slip on and the tranny a got was a bolt on but they used the slip on yoke. so i am looking for a bolt on turbo 400 with drive saft with it.
Old 03-21-2002, 03:30 PM
Post
Puffer37
Need more info year of truck were you certain it was a 400 trans, it doesn't sound like it was,all
the400 trans I've seen had a slide on yoke with a bolt in the output shaft of and driveshaft bolts to it. Also 400 has larger yoke and more spines 350 has smaller yoke less slines. 350 yoke can,t fit a 400 and vise versa. It sounds almost like your truck has a older GM 375 auto trans in it not the 350 or 400. but this purely a guess.without knowing year of truck is the trans motor been changed.metric trans poss installed?????
NOVA JEFF
Old 03-21-2002, 06:32 PM
Tom Tom is offline
Post
a turbo 375 is basically a turbo350 with one extra clutch and steel in each pack from the outside you couldn't tell the diffrence and in all the th400s I've seen I never saw a bolt on yoke not saying they didn't make one but I have seen thousands and never a bolt on. if the drive shaft yoke moves up and down after a rebuild it was only partially rebuilt probably they just put new clutches and steels along with a few gaskets and the output shaft berings weren't replaced
Old 03-22-2002, 07:18 AM
Post
TOM COULD BE RIGHT, BUT WITH LITTLE INFO ON THE ORIGINAL PROBLEM I ONLY COULD SUPPLY A GUESS. I KNOW I SEEN A LOT OF CHEV VANS WITH THE BOLT ON U-JOINT FLANGE BOLTED TO TRANS THESE WERE 2 PIECE DRIVE SHAFTS. NOT KNOWING THE VEHICLE YEAR OR 1-2 PIECE SHAFT ONE CAN ONLY GUESS. I THINK HE SHOULD TAKE IT BACK TO THE SHOP WERE IT WAS DONE AND FIND OUT WHAT WAS DONE, AND TELL THEM TO FIX IT RIGHT!!! on the original post
NOVA JEFF
