Need help Troubleshooting - Low power at coil - no spark....help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2009, 12:39 PM
The car is a 84 TA with a 355, T1 heads, good size cam etc etc...My ignition system is a Holley Annihilator Ignition box & a Lasershot Prostrip coil.
Yesterday, while driving my car, it seems like every time I would come to a stop, my car would want to die, I first thought it was fuel, but I have confirmed its getting good fuel, I now knows its an ignition problem.
So, no spark, no running engine. When I put a test light on the positive side of the coil and crank the motor over, it gets power but the test light is very faint, like its getting a much lower then normal voltage.
Would this cause a no spark condition or is this normal?
At this point, I know the pickup in the dist. is working because its signaling the ign. box to charge the coil, so im thinking its the ign. box not sending enough power to the coil so the coil cant jump it up enough to get the spark plugs to spark?
According to this
http://p-928.home.comcast.net/~p-928/199R9949-1_HP.PDF
On page 23, it says the voltage output for this ign. box is 525 volts, if that's true, it would have blown my test light correct???
Am I off base here or what??
Any other ideas?
Old 06-14-2009, 05:45 PM
UPDATE:
Coil failure. Was getting voltage to coil, nothing coming out. The back of the coil had exploded and was leaking a tar like substance.
Put a new coil on and she started right up.
Building sbc low end power stoplight king Engine 1 04-24-2009 09:33 PM
Weak Spark off Coil!?? 11echo Electrical 16 03-01-2009 01:38 PM
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
help me PLEASE! no spark, no power, dieseling byrdta76 Engine 4 06-23-2006 11:44 AM
low power vette john69 Engine 1 09-01-2002 09:51 AM
