Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help tuning my Edelbrock 600 cfm carb
Old 01-26-2013, 02:56 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Wiki Edits: 326
Whenever ignition timing is mentioned, I wonder if the poster is aware that the TDC mark on the inertia ring of the harmonic damper is capable of rotating on the elastomeric material that separates the inertia ring from the hub. If that has happened (very common), it will be impossible to set the ignition timing correctly. Please read through this tutorial.....
http://www.crankshaftcoalition.com/w...op_dead_center
