Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help tuning my Edelbrock 600 cfm carb
Old 01-28-2013, 02:19 AM
JeffB's Avatar
JeffB JeffB is offline
Look at the accelerator pump it is probably set it the center hole,try placing the link in either the top or bottom hole and road test it.Most of the time it will cure your bog issue.To do further tuning order an Edelbrock kit #1487.
The Following User Says Thank You to JeffB For This Useful Post:
techinspector1 (01-28-2013)
