Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help tuning my Edelbrock 600 cfm carb
Old 01-28-2013, 06:33 AM
33Willys77's Avatar
33Willys77 33Willys77 is offline
When setting the timing, get all the intial you can - without making hard starts (difficult to tell without knowing cam specs). Edelbrock carbs work much better with more intial timing. If you can get it to 14-16 intital, you will probably see a difference with the stumble. May also need more (dought it would be less) of a shot of gas (pump adjustment). Take others advice and get the timing set and read the manual - you will learn much more by reading the book than just playing with the carb.
