Originally Posted by carsavvycook
Get a taller set of valve covers. It will solve your aggravation from consumption.
I pulled the PCV and it was full of oil. Also, the hose from the PCV to the base of the carb was filled with oil, so was the base of my carb and the top side of my blower. My vacuum gauge line also had some oil in it. I dumped the PCV and hose and instead added another breather. Next I installed new plugs with a step up in heat range. That should do it, but I know I will have a smoke show when it starts because of all that oil my blower sucked into the cylinders. Wish me luck!!
