Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help????with tunnelram set-up on sb350..
Old 12-24-2003, 11:10 AM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
You should recurve the distributor. Run it with 18o distributor advance and 16 initial. I would get a Mallory Unilite with mechanical advance also. Look on Ebay, they are cheap. You might need more accelerator pump shot as well.
Gears will help too. They aren't that expensive, and will make a big difference.
