Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help????with tunnelram set-up on sb350..
Old 12-24-2003, 07:05 PM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Robbie,
Don't compare yourcar to your friend's, BECUSE ITS NOT THE SAME, you already found that out. Pro's can't even build two engines that are the same, how can we? Everyone is giving you good advice, take this information and study it, ready some good tech articles, ask some more questions, get some more advice and decide on a plan of action. Only change one thing at a time and note the results.
Consult with the cam manufacture as to what stall, gear ratio, tire size,l etc that he recommends for that grind. Re-read the advice that was given to you today and see how that equates.
Good luck.
