need help in using a magnetic mount caster/camber gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2013, 01:29 PM
help, i just picked up a intercomp magnetic mount caster camber gauge
can somebody assist me in going through the proper procedure in using this tool for aligning my front end,
using a stock MII crossmember fitted as low as i could with out c notching the front frame horns for rack clearance and the lower control arm bolts level to the ground front to rear
and frame rails at @4 degree rake
car is a ford a coupe
thanks for the help
dave
Old 03-31-2013, 08:09 PM
BOBCRMAN@aol.com's Avatar
Try this How To Align Your Street Rod's Frontend - Tech Articles - Street Rodder Magazine or this http://www.mustangii.net/forums/topic.asp?TOPIC_ID=7323
Old 03-31-2013, 09:00 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Which version do you have the bubble one or the digital? should be able to get a manual from intercomp..
Sam
Old 03-31-2013, 11:59 PM
using the caster/camber bubble gauge
Ok here go's
The gauge has three bubbles center adjustable for caster
Tthe outer bubbles are fixed solid for camber
and one small outer for leveling front/back.
Camber
After mounting the magnetic bubble gauge on the hub face,
Zero the outside bubble
Read the camber bubbles
If positive camber bubble gauge reads 0 then read negitive camber bubble gauge
If negative camber bubble gauge reads0then read the positive camber bubble gauge
Caster
With the gauge mounted on the hub
turn left front wheel to right @15/20 degrees
zero the outer bubble
Adjust the caster bubble to zero
turn left front wheel rear word past center all the way to @15/20 degrees
Zero the outer bubble
Read the degrees caster
(how come it reads on the neg caster bubble say 3 degrees)
When at the same time using another tool designed to read off the ball joint centers reads 3 degrees pos
But if i reverse the procedure
Left front wheel turned left
The gauge will read in the positive side of the caster bubble
This is where i need some help in clearing up whats going on here.
setting camber/caster scfalk Suspension - Brakes - Steering 3 07-19-2012 02:09 PM
Caster/Camber Gauge steve392 Suspension - Brakes - Steering 1 11-28-2006 06:51 AM
Caster--Camber Bryan59EC Suspension - Brakes - Steering 14 07-22-2006 08:50 PM
Caster and Camber bigiron40 Suspension - Brakes - Steering 14 12-12-2005 12:20 PM
Caster and Camber WilderRods Suspension - Brakes - Steering 2 01-17-2005 02:05 PM
