Need help w/ knocking 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2009, 07:03 PM
I got a 350 vortec that runs fine when initially cranked but starts to know after it gets to operating temp. Does any one have an idea of what that could be????
Old 09-06-2009, 07:06 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Hows the oil pressure? Could be a rod bearing . Is it a knock or a ticking sound. Cole
Old 09-06-2009, 07:10 PM
dont know....dont have an oil pressure gauge hooked up......if I hook one up what do I need to look for & could the engine temp cause the oil pressure to drop???
Old 09-06-2009, 07:20 PM
eloc431962's Avatar
Wiki Edits: 37
Yes it will usually drop after warms up, depending on how much it drops though, It sounds to me like it might be a bearing and if you spin a bearing it will get your crank when it goes if hase'nt already and can get more depending on how severe it is, Now i am not saying it's a bearing gone put but it has the symptom's of it. Have you changed your oil lately if not you can drain the oil and check for metal in the oil/oil pan.Did it just start doing this ?JMO. Cole
Old 09-06-2009, 07:26 PM
E, I appreciate you sharing that knowledge w/ me.....that'll be the first thing I'll check.....could it be anything else. I ask b/c I've pulled it out of car already and wanna check every possible cause before putting it into my truck.
Old 09-06-2009, 07:30 PM
eloc431962's Avatar
Wiki Edits: 37
If you have it out nows the time to drop the pan and check for metal in the pan and check the bearings. may be time for a overhaul. When you start pulling rod caps and main caps be sure to mark them so to put them back where they came from, Good luck. Cole
Old 09-06-2009, 07:39 PM
K....thanks Cole
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
