need help with what stall converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2005, 06:44 PM
bb1 bb1 is offline
need input on what stall speed converter to install, 73 corvette,3400 lbs,350 engine,bored 30 over, 11-1 pistons,roller rockers,street cam,original factory heads,eldebrock performer intake, eldebrock 650 thunder series carb,th400 trans with shift kit, 4:11 rear. will be driving on the street. not really sure of cam lift & duration. when engine was rebuilt i said i wanted a cam with mild lope when idiling. been told at ramchargers a 2400 stall, told at tci converters a 3000 stall. i will be driving car on the street. 202 camel heads
Old 08-24-2005, 07:10 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
11.1 compression, factory heads, 4.11 gears and no Idea about cam size. Sounds like several mismatched parts. I would say a 3000 would be too big. I would say 2500 thats just a guess.
Old 08-24-2005, 07:18 PM
bb1 bb1 is offline
heads
its 202 camel heads
Old 08-24-2005, 08:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by bb1
its 202 camel heads
The heads are bit old tech for modern engines, they will not hurt anything.
the cam specs are more important for torque converter selection
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
please recommend me a stall converter smlblcks10 Engine 6 02-09-2005 06:41 AM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 04:04 PM
checking stall on converter Checy_Guy Transmission - Rearend 1 07-21-2004 09:06 AM
Stall Converter novatech Transmission - Rearend 2 07-21-2003 10:24 AM
