Need help, why engine is knocking. - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Is it possible that they sent the wrong part and caused the damage?
Yes. 0 0%
No. 1 100.00%
Voters: 1. You may not vote on this poll
Old 08-25-2010, 08:45 PM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
Well title says it all, I have a nasty rod knock, now I'm sitting here thinking about what could have possibly caused it. I have a serous question here, if this is possible let me know, if you do not think its possible let me know. I'm setting up a poll and hoping for fast responses before I get a chance to call this transmission shop in the morning.
I replaced my transmission and engine @ 161900 miles, current reading is 193446 miles. Engine is a 360 Magnum (mopar), which is externally balanced w/ the flywheel/torque converter (weighted). The 318 Magnum is a internally balanced engine with no weights externally (naked flywheel/torque converter).
Is it possible that they sent me the wrong torque converter and that is what is causing my engine to go into self destruct mode?
Old 08-25-2010, 09:31 PM
Eric63M's Avatar
Can't seem to find the edit button from my phone. The current mileage is 163446 not 193446. I guess I messed up that post in my rush. Current mileage on both is 2546 miles.
Old 08-26-2010, 02:11 AM
ericnova72's Avatar
More for Less Racer
It is possible, but would have shown up as a vibration the minute it was first started up after the swap.
Did you inspect the converter and flexplate for compatability?? Compare them to the old parts??
It would have been your responsibility to make sure parts were compatable/correct, not theirs, if you were the installer. If they installed, then it would be on them.
Unless you can confirm the converter and flexplate weighting is correct/incorrect, it is impossible to say this is definately the problem. Could be some other internal problem to the engine.
Old 08-26-2010, 07:23 AM
bigdog7373's Avatar
Of course it's fast
Make sure the flywheel bolts and torque converter bolts are tight. If one is loose it will sound like it's knocking. Did you build this engine? If so, did you check all the bearing clearances?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 09:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
engine developed knocking sound sune Engine 6 09-06-2004 02:40 PM
