need help with windsheild - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2011, 06:35 PM
DARK SIDE's Avatar
I can not find anyone that knows how to install a windsheild in my 1952 buick super. Broke one already. I live in St.Catharines Ontario Canada. Anyone out there know of anybody??? need help before the snow flys....thax
Old 09-26-2011, 07:30 PM
Is there a reason you can't take it to an auto glass shop? A friend of mine runs one and I don't think he'd have a problem doing it.
Old 09-26-2011, 07:57 PM
Cape Cod Bob's Avatar
Maybe this link will help.
http://www.mustangmonthly.com/techar...t/viewall.html
Old 09-26-2011, 08:04 PM
DARK SIDE's Avatar
windshield
had 2 different shops come to my house...couldn't do it. One blamed the windshield other blamed the rubber.... Replaced both...still won't go in.
Old 09-26-2011, 09:22 PM
Wiki Edits: 27
glass install
First are the opening flanges in good shape.? I usually use a hammer and dolly and smooth up the spot weld areas. Are the lap joints smooth ? Do you need to grind off protrusions? In the factory they used to have heat lamps over the bins of rubber parts to soften them, The Mustang article referenced shows applying a lot of sealer before installation. If you are not experienced it can get messy. When they shut down the old Ford mustang assembly plant in Calif I got a few of the glass installation tools. You can work the nylon sash cord into the grove by hand. I have the factory tool. a screwdriver with a small ring welded to the end and hammered oval shaped. Thread the cord thru the needle eye then install it in about 10 seconds, Another usefull tool is a screwdriver modified by turning the shaft in a lathe, ending up with a 1/4 inch ball on the end and a 3 inch taper from the 1/4 inch shaft down to 1/8 just before the ball. It is bent L shaped with the ball about an inch from the bend, It is used to help pull the rubber inside the flange if the cord does not get it in easily. There were times when a welding clamp was not closed tight enough and the windshield opening was not to specification . They used to have a large grinding machine, a wet belt sander with guide rollers and resized the glass to fit. Usually a soap solution was used to lubricate the rubber. On trucks they used kerosene for lube.
Old 09-27-2011, 05:44 PM
DARK SIDE's Avatar
windshield
Everything on the body is as it should be. I have a small plastic stick I use to put in the cord. The problem seems to be I can't find anyone who knows how to do the buick. All I get is "they are a real ***** to work on" There has to be a trick to get it to fit. Maybe it has to be put in top first. Tried it and it was closer to getting in but not enough. I would really like to talk to someone that has done this type of car...I have tried it 7 times but no luck. Maybe the rubber is too big but steeles rubber says they have had no complaints about their rubbers. Starting to think I will have to cut a 1/4 in. from the top of the glass to make it fit. Some where someone has done a 52 buick super so any info would help.
Old 09-28-2011, 06:08 AM
Install the rubber on the pinch weld as is you had the glass in place.
Now insert paint stirring sticks at a few locations in the upper and lower portions of the gasket, directly opposing each other in pairs.
Make sure each stick is fully inserted, then make a reference mark on each stick at the gaskets edge.
Next measure the distance from mark to mark on each pair of sticks.
Remove sticks and add the additional insertion depth of each pair of sticks tothe measurement taken for that pair.
Now you have the maximum distance available for the glass sizing.
Measure you windshield, you should have at least a 1/16 smaller measurement on the glass at the corresponding stick measurement.
If this all checks out, then it is just a technique problem, Good Luck
Old 09-28-2011, 04:08 PM
DARK SIDE's Avatar
windshield
This is a great idea. I was trying to measure the opening but couldn't get a good measurement. Great idea. Talked to one guy who has doing windshields for 40 years. He said the last old car he did was an old chev that had a similar set up. First time would not fit ..second time he sanded off 1/4 in. from the glass and it slid right in. Will try to measure this weekend. Think im going to end up shortening the glass.Thax again..
Old 09-30-2011, 06:18 PM
DARK SIDE's Avatar
windshield
Checked all the measurements. 1/8 in.everywhere except where windshield wiper posts go through rubber. There i have nothing. Don't know if I should try and shave the rubber . Not very thick there at all. If I take off to much I will go through to the wiper holes. Hmmmmm. Any thoughts?
no windsheild wiper RattVette Electrical 0 05-22-2010 07:31 AM
Windsheild glass MyChevy51 Body - Exterior 3 12-30-2008 05:49 PM
windsheild Question stoney 81ta Body - Exterior 0 06-27-2006 11:05 PM
need windsheild frame bigrat Body - Exterior 2 12-22-2005 07:38 PM
windsheild removal docs57 Body - Exterior 3 02-26-2005 07:50 AM
