Need help wiring a chevy 305 small block?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2011, 08:02 AM
Ok so I need to wire a 1986 305 small block. So from what I have seen the starter solenoid, the carburetor, the distributor coil go to 12volt when ignition key is turned to start right? Then also the starter and the alternator hook up to battery? So is that basically it or am I missing something in the wiring?
Old 03-16-2011, 08:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What vehicle, is the computer being used?
Old 03-16-2011, 08:27 AM
Its in a nissan 240sx so im just trying to figure out the simplest way.
Old 03-16-2011, 08:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
12V switched to the HEI
Battery cable from the battery to the starter solenoid
The "S" terminal of the starter solenoid through the neutral safety switch to the ignition switch
12V switched to the electric choke
Alternator depends on type, more- http://www.alternatorparts.com/FAQ.htm#how_to_wire
Grounds from battery to engine (often to the alternator bracket of a long water pump set-up) and to chassis/front end sheet metal, engine to frame and firewall.
Can't have too many grounds. Ground to bare metal and use good quality terminals and tooling. Use adaquate sized wiring throughout.
Depending on your particular wants and needs, you may want to use a 1 wire alternator, and/or a Ford-type solenoid.
Old 03-16-2011, 09:10 AM
When you say 12volt switched thats only 12volt when its switched to start position? So I think I got just bout everything except for the wiring of the starter where it goes to the neutral safety switch to the ignition switch? So am I going to be using 2 wires or 1 on wiring neutral safety switch to ignition switch for the starter?
Old 03-16-2011, 10:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need 12V to the HEI in "Start" and "Run". For the choke, you need 12V in "Run". There are other ways to do this so the choke doesn't warm up until the engine is started, but unless you were to leave the key in "Run" w/o the engine actually running, this isn't necessary.
Are you using a GM column w/the NS switch mounted to it? Some aftermarket shifters (if AT) will have the NS switch as part of the shifter.
Basically, if using the existing set-up from the Fiero, the purple wire will go down to the starter from the NS switch, the other side of the switch goes up to the ignition switch.
Old 03-16-2011, 10:23 AM
Ok so I get the neutral safety switch now thanks. With the HEI to 12volt start and run, also the starter and electric choke will get 12volts but on start and run also like the HEI? Or only on run when I turn the key?
Old 03-16-2011, 10:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The starter gets power through the NS switch in "Start" only. The choke in "Run" only. The HEI in both "Start" and "Run".
Old 03-16-2011, 10:37 AM
Ok got it. You have been alot of help!!! because I have heard so many different ways to hook it up. But finally that sounds right lol.
Thanks Sean
Old 03-16-2011, 01:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Don't ask me how I got "Fiero" out of "nissan 240sx". Sorry if that caused any confusion.
If the Nissan uses a similar switch, you can use it. Or if you have an aftermarket shifter it may have the switch. Or you can even use a simple relay set-up to get 'er done.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 09:39 AM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 08:26 AM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 12:55 PM
55 chevy small block to big block ehchvac Engine 0 05-02-2002 09:23 PM
