Need help wiring my 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2008, 04:35 PM
I'm new to the board and need a little help with wiring. I have a 1986 700r4 serial no. 6YLM285A (I don't know what vehicle it came out of) that I'm installing in a '62 Impala. I've looked on the net and at several threads on this forum and found that there are too many different wiring combinations. I believe I have a single wire lockup. I only have a light green wire running to the "A" terminal on the tranny. If you pull the male connector out of the tranny, there are a total of three pins in the tranny but the male end only has one on the "A" with the green wire. Can I just hook up a switched 12v supply to this wire and have a switch break this 12v line when the brake pedal is depressed?
Any help is appreciated. Thanks.
Old 01-21-2008, 06:19 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Hook up 12 volts to the "A" location. this is the OEM location for 12 volts.
You 'may need" a ground wire to the "D" location on this same plug for lock up of the converter to operate.
Do you know if the trans was built for one wire operation or simply a guess since the connector had 1 wire on it?
Old 01-21-2008, 06:40 AM
406chevycaprice's Avatar
"CHEVY"THE ANTI-RICE!!!
re: Need help wiring my 700r4
here this mite help
Old 01-21-2008, 02:02 PM
Thanks for looking at my post Crosley. It is my "guess" that this is a single wire lockup as the factory male end with the single wire was included with the tranny and only has one terminal and wire on it. More info on the tranny - I called the guy I got it from and he says it was removed from a 1986 Chev Caprice Classic if this helps.
Should I ground the "D" terminal as shown in the diagram that 406ChevyCaprice posted with a switched ground?
Thanks again guys.
700R4 LockUp wiring diagram chevychase Transmission - Rearend 9 03-29-2016 06:54 PM
Wiring switch for 700R4 dontnobetter Electrical 3 11-15-2006 12:26 AM
Redneck-rigged VSS wiring question for 700R4 Mad Maggot Transmission - Rearend 1 02-21-2006 08:49 AM
700R4 1984-87 GMC PICKUP wiring will8243 Transmission - Rearend 3 06-03-2005 08:14 AM
700r4 wiring questions murrsue Transmission - Rearend 4 02-04-2005 10:09 PM
