Need help wiring my cluster
I have a 1980 Camaro, and adding Z28 parts, I have removed my Cluster and installed a 1980 Z28 cluster, I need to know how to re-wire it to work right. I have already ran a wire from my distributor for the Tach, I just need to know where on the big plug to put it.. Nothing on my Cluster is working at this time.
Any help would be appreciated. ke5bgv |
what I did was run a wire from the coil, to the main plug on the cluster. Someone else on this board pointed to a diagram, that showed multiple wires had to be moved on the main wire harness, and the coil wire ran to the number one plug. Once I did this and put the cluster in place, Cranked the car and my RPM guage is now working fine. Thanks to all the help.. Now, I see a couple of you said Ground. On the back of the RPM guage are 3 stluds with plastic looking screws of some sort are tight on them, Nothing is coming off of any. I have no idea, if I need to do anything there.
Scott , ke5bgv |
| 70-72 Chevelle Chevelle dash wiring Problem | skeeveman | Electrical | 18 | 01-10-2011 07:44 PM |
| 66 mustang gauge cluster wiring harness | SouthernRascal39 | Electrical | 2 | 04-14-2009 10:19 AM |
| EZ wiring project | zipfactor | Electrical | 3 | 05-21-2006 03:55 PM |
| mustang tach wiring | stang_steve | Electrical | 0 | 07-14-2004 07:28 PM |
| 79 firebird wiring diagram for dash cluster | Jzilla | Electrical | 2 | 08-04-2003 05:46 PM |
