Need help with wiring starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2012, 08:42 AM
I have a 1987 gmc classic sierra,the starter was bad so my brother in law took it out but he cut all the wires,I put in the new starter but I have know idea where the wires go other then then battery wire,I dont know where the remaining three wires belong,I would really appericiate any help or advice anyone.
Old 01-27-2012, 05:48 PM
LATECH's Avatar
There is a purple wire that is 12 gauge, that will hook to the "S' terminal of the starter
The other 2 wires are most likely fuse links that bolted under the big post on the starter where the big cable goes,they feed the vehicle its power, they are circuit protection devices.
Old 01-27-2012, 06:03 PM
The purple wire (running from the ignition switch and down through the metal tube on the back of the engine) goes to the S terminal.
All the rest of the wires connect to the large starter terminal. In most cases it should be these three wires.
- large (2 gauge?) wire running up along the flange of the oil pan to a point where the mechanical fuel pump mounts (I assume you have an electric pump), over toward the frame, and then to battery positive
- 10 gauge with fusible link running up through a metal tube on the back of the engine and up to alternator BAT terminal
- 10 gauge running through the same metal tube and up to the fuse box
Bruce
need help with starter wiring on 87 sbc ryan v Electrical 2 08-19-2011 04:02 PM
starter wiring bigdog7373 Engine 1 07-01-2010 10:29 AM
starter wiring tommer2 Electrical 1 01-14-2009 12:09 PM
Starter wiring Cliff34 Electrical 6 12-18-2006 05:14 AM
Starter wiring dlsalty Engine 3 08-14-2004 04:26 PM
