Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help With Wiring Trailer Brake Control
Old 03-22-2012, 10:09 PM
adantessr's Avatar
adantessr adantessr is offline
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I Took A Slightly Different Route And I Got It !
Every once in a while I manage to be just a little bit smarter than what I am working on. I located the brake light relay under the hood. I then determined which spade of the relay was power out. Then I took a 16ga. wire and stuck it in the spade socket in the junction block along with the power out spade. Added benefit of doing it this way, is that it keeps from putting any additional load on the brake light switch.
