Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help With Wiring Trailer Brake Control
Old 03-22-2012, 09:09 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
Typically GM used the white wire from the brake light switch to the turn signal switch. This white wire can be found at the connector at the bottom of the steering column as the wires go into the steering column.
vicrod
